- 24 May 2003
- UK
I have just recently noticed that when I type my number into http://www.samknows.com/broadband/ I get this:
I also get a similar result when I go to http://www.prodigynet.co.uk/menu.php?page=support/adsllinecheck
Also when I use the 'official' BT estimator http://www.btwholesale.com/get_broadband/index.html I get the same story.
What I think is happening is that BT are updating the 'estimators' based on feedback from people on Max connections?
I only noticed this a few hours ago as before this change I used to have green for 512 Kb, amber (possible engineer visit to deliver the service) for 1 Mb and red for 2 Mb.
Also I used to be told that 3 Mb (or higher) might be available on Max and now it's 4 Mb (or higher) which is right if you include overheads as I am syncing at just over 4 Mb on a 3.5 Mb BRAS profile.
Has anyone else noticed this
I could get 2.5Mbps speeds during the day but at night my stats drop unfortunately. My stats are a little better than yours as well, my line attenuation is 56.0 dB. My SNR margin and sync speed are lower at night.
