BT Home Hub 3
19 Jan 2010
South West
Just had fttc installed, came with the BT Home Hub 3.
But, the BT Home Hub 3 only has gigabit port, is only single-band 2.4Ghz router, no 5GHz frequency band for wireless.:mad:
What can I replace it with, a few more features would be nice.
Hi, I'm currently using Netgear N900 with BT can't fault the router great! Make sure you enter the pppoe settings with a third party router. (Username: [email protected])
Also you can get a vDSL modem and Router built into one such as Billion BiPAC 8200N or Drayteck Vigor 2750
Thanks for the reply,have looked at the Billion 8200N, but I think the Drayteck Vigor 2750n is a better choice, as it has four gigabit ethernet ports.
