- 2 Sep 2013
Got a weird one here. Haven't found the solution on my own just yet, so hitting here to see if anyone has an idea on what to do to solve the issue or whether I'm stuck with the situation I'm in.
So, the home network is roughly as follows:
Home Hub 5
| |--> Synology DS215J
|---> Switch ---> Connected devices
The issue is whenever the Home Hub 5 resets every 2-3 weeks and reconnects to the Internet, the Synology is not immediately accessible to the rest of the network. It appears to be reachable after a certain amount of time, but I am unsure whether it's just the expiry of the lease it's given and so the Home Hub renews it on the network to make it accessible again. Optionally as it's right next to me I can just pull the ethernet out from the Home Hub 5 and reconnect it again, that solves the issue 100% of the time.
Anyone have an idea on what setting I need to modify to get this sorted without resorting to needing to be there physically to disconnect and reconnect it?
Home Hub 5
| |--> Synology DS215J
