BT Home Hub 5 channels
27 Jan 2005
Letchworth Herts uk
Hi All i,m wondering if changing my wifi channel on the BT Home Hub 5 with Infinity 2 would make much difference with my wifi connection ,i downloaded the software InSSIDer and notice no one around me is on channel 40 on 5ghz ,or would it be best to leave it on auto ? any views thanks
If the router is on auto then a reboot will do what you need it to. When it comes up it will scan locally and move to an appropriate alternative if needed.
