BT homehub 2.0 Port Forwarding.
21 Dec 2011
Hi guys, I really need to forward ports with BT homehub 2.0. However, I have forwarded them all properly, and they are still not open!.
For example, I have setup a minecraft bukkit server, forwarded the ports 25565, No one can join, and when using tools such as port checker it says it can't connect to my ports.
Upnp. If that doesn't work double check your firewall/ reset the router or failing that, try borrowing a router for someone. Odds are it's simply the home hub being poo.
BT HH 2.0 can be a right pain to forward ports on. Have you tried setting it as a DMZ, are you sure you have a static IP on the server because it's much better with a static IP rather than a host name?
