Hey guys
I've got a network at my uni room which is doing my nut in. When nobody is online (ie right now) I get rock solid consistency in download/upload speeds. They're pretty unimpressive at 1.96/0.69 Mbps (speedtest.net), but they're consistent to within 0.02Mbps and usable, if hardly lightning.
When a couple of housemates are using youtube or general internet it degrades a little, to about 1.3/1.4Mbps, which is still usable - by which I mean I can stream iPlayer without interfering with their download speeds too much.
However, as soon as my third (bit of a ********, so unwilling to compromise) starts streaming, bandwidth on the rest of the network plummets: I get 0.21 and 0.06Mbps through to my laptop, and if streaming on my xbox I just get constant buffering (we're talking 1999 Realplayer, here)... while she gets absolutely no problems. I've not been able to run a speed test, but her streaming works fine and she's able to browse at the same time.
It's not as if I want all the bandwidth, just enough to allow 2 streams (mine and hers) over 2Mbps (more than enough) and still be able to download lecture notes. 0.21Mbps means I take about 5 minutes to download a single PDF, and really isn't good enough. My laptop isn't causing any problems, as when I go to uni I get 25Mbps on the wireless, and 96Mbps off the LAN - so between 4MBps and 12MBps actual download speeds.
However, we've got BT (nothing I can do about it, as it was contracted before I moved in) with a stupid BT HomeHub3 - it was a 2 until Monday, when a tech (ha) came around, poked around, declared he couldn't do anything about it other than give us a new router and leave it a few days to see if that helps.
So yeah, I'm pretty fed up - it's getting to the stage where I'm having to drive to campus every time I want to do anything, as it's working out faster to drive there, download any material and drive back.
I've got a wireless access point lying around, if that helps (all the above devices are wired in), but no router. Could I turn this on with it's QoS settings, keep the SSID and password the same as the BTHH3 and tell my housemates it's the same network? (Or rather, would that help my speed issue? I'll deal with the moral issue of lying to my housemates)
I'm thinking it's worth a go, before getting hold of a router and messing about with that.
