Have been having an ongoing problem with my BT connection since just before Christmas with constant pauses of up to 2-3 minutes while doing anything on the internet.
Loading a web page might be fine one minute and then clicking a link might also load fine. But try the same links or webpage again and the connection times out or loads half the page and then stops doing anything at all.
I can forget streaming video or music of any kind as it will only buffer so far and then the connection will just seem to hang. Similarly gaming is out of the question with pings sitting around 100ms then spiking up to 15,000+. My connection wont drop out but no information comes in or goes out during that time.
BT are saying there is nothing wrong with my line and that the problems must be with my wireless network but streaming anything between computers is fine and i even went as far as to wire everything on the network and the problem still persists.
I dont know enough about these sort of things to have it out over the phone with BT so was hoping someone here might be able to shed some light on my problem or help.
Line Status Below.
ADSL line status
Connection information
Line state Connected
Connection time 12 days, 15:30:55
Downstream 6,912 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 6.1 dB / 21.0 dB
Line attenuation (Down/Up) 29.0 dB / 15.5 dB
Output power (Down/Up) 19.8 dBm / 12.1 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 314035 / 39
CRC Errors (Down/Up) 1273 / 2147480000
HEC Errors (Down/Up) nil / 21
Error Seconds (Local) 591
Line Status Below.
ADSL line status
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
