- 28 Jan 2005
- Southport
Hi all,
Moved into my new house over the weekend and noticed there was no phone socket anywhere in the house. After some looking around I found this little mess under the stairs:
The thick black cable is the main feed from BT to the house and the littler cable goes back out the wall and up into the loft which I cant find anywhere.
Now I know "This side of the socket" is property of BT and cannot be altered. So hypothetically speaking if a BT engineer was to wire the orange and white cables from the main feed into a BT80a junction box and then run a small length of cat5e cable to a nice new NTE5 master socket this should be common practice for them?
I could then leave the master socket and the router under the stairs and then run cat5 cable from the router?
