BT speed and dissconect issues
11 Nov 2004
Macclesfield, Cheshire, U
I'm on 20mb bt broadband , I was reviving 5mb dl speeds untill day three, for the three weeks after that I've been getting 1.5 mb download speeds. Also when i start a call of my landline my routers Internet goes off, ive tried swapping Adsl filters and everything........ Edit , dam iPhone spell checker
I'll go with "you've had loads of line errors, possibly due to a line fault.. the DSLAM has interpreted this as unstable and lowered your target margin to increase stability".
I bet you the noise margin is now 15dB, and you'll be stuck at this speed for a few weeks / until the fault it fixed.
Try a phone at the master socket. If you can hear noise, call 151 and report a voice fault.
Yeah I hear noise but only when sum1 speaks , verry crackley. I have rang bt and they say my line should handle 7 meg and they will try and fix it , am debating switching to infinity , thanx for your post
People saying about line stats, when I go to that ip it's my routers cp, I see no "line stats"?
I found this in event log tho
21:49:31, 10 Mar. (92702.370000) DSL noise margin: 3.70 dB upstream, 6.80 dB downstream
21:49:30, 10 Mar. (92701.320000) DSL line rate: 176 Kbps upstream, 3072 Kbps downstream
21:49:02, 10 Mar. (92673.930000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
21:48:58, 10 Mar. (92670.000000) DSL is down after 39 minutes uptime
21:48:57, 10 Mar. (92668.640000) PPPoA is down after 39 minutes uptime
21:22:47, 10 Mar. (91098.290000) Lease for IP 192.168.1.64 renewed by host Vinces-iPhone (MAC 58:1f:aa:c9:f3:85). Lease duration: 1440 min
21:22:47, 10 Mar. (91098.280000) Lease requested
21:22:47, 10 Mar. Host 58:1f:aa:c9:f3:85 connected to SSID 'BTHub3-SP4T' at 39 Mbps
21:09:44, 10 Mar. (90316.120000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
Rite ok thanx do I've done that now and am awaiting a tekki , rite now bt is been helpfull , or seem to be , they assured me ut would b resolved today anyway.. But we shall see
Rite, ok so basically if this guy just shoves summet in my line and runs a test and says he is done , I want more? That's all they did when they installed my broadband
