I've recently upgraded my BT business hub to a Buffalo Airstation running DDWRT. So far I've setup the router to obtain a dynamic IP, however I want to setup a single server on the network with It's own static IP address. I figured out how to do it on the BTHub, but can't figure it out on the new router. I'd like to keep the whole network NAT'ed and not have to purchase two routers if possible.
In the BT business hub I had it setup as follows (IP's Censored for security):
Then on the Server ifconfig was setup as follows:
I'm not entirely sure of what to configure on the DDWRT firmware to mimmic this setup
So far I've taken a guess and configured "Advanced Routing" as follows:
I've also disabled the firewall temporally for testing, and forwarded port 80 and 448.
And as you can probably guess, I'm having no luck whatsoever. When I try and access the IP, Safari returns "The server where this page is located isn't responding"
It's probably way off track, but I'm brand new to networking so please go easy. If anyone has any ideas they would be greatly appreciated.
Thanks in advance.
Code:
Router Address: 111.11.111.118
Subnet Mask: 255:255:255:248
Allow Ping: Yes.
Code:
eth0 inet addr:111.11.111.113 Bcast:111.11.111.119 Mask:255.255.255.248
lo inet addr:127.0.0.1 Mask:255.0.0.0
Code:
Operating Mode: Gateway
Set Number: 1 (Server)
Route Name: Server
Metric: 1
Destination LAN NET: 111.11.111.113
Subnet Mask: 255.255.255.248
Gateway: 111.11.111.118
Interface: WAN
Thanks in advance.
