can you use a 3rd party router with BT total broadband?
What are the correct settings?
Are these correct:
Logon username: Created when setting up your account - example: [email protected]
Logon password: No password is required, as BT uses the phone number you're connecting via for authentication. If your router needs one, use "BT"
Encapsulation: PPPoA or PPP over ATM
15,800.00 VC-based or VC Mux
VPI/VCI: 0/38
BT Broadband Primary DNS address: 62.6.40.162
BT Broadband Secondary DNS address: 194.72.0.98
Incoming POP email server: mail.btinternet.com
Outgoing SMTP email server: mail.btinternet.com (Sending email requires SMTP server authentication - you need to enter your BT Broadband account's username and password as well as your SMTP address)
Are these correct:
VPI/VCI: 0/38
