Hi,
the in laws have been having problems with BT for a good year now (since he joined). Slow internet speeds day and night, BT call center have sent out engineers to have the line moved etc etc, plugged directly into master socket etc but still having no luck.
Could someone please have a look at the line stats below and tell me what sort of connect he should be getting?
The only other ISP in the area is Sky, but they have no room on the exchange so they say.
If you need anymore info please let me know.
Thanks
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 1440 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 135 kbps <-------- WTF surely that's way too low?
Actual IP throughput achieved during the test was - 80 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
DSL Connection
Link Information
Uptime: 0 days, 13:57:09
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,440
Data Transferred (Sent/Received) [MB/MB]: 46.27 / 110.64
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.0
SN Margin (Up/Down) [dB]: 16.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 7 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 / 0
FEC Errors (Up/Down): 0 / 6,908
CRC Errors (Up/Down): 0 / 55
HEC Errors (Up/Down): 0 / 47
Line Profile: Interleaved
Thanks
DSL Connection
Link Information
