I'm trying to set up my wireless internet connection using the BT homehub 2 wireless router. Setting up a wired connection is straight forward - hence why I can write this email.
Setting up the wireless connection is proving harder. During the setup the wireless connectivity box seems OK but when it wants my wireless key that is supplied with the hub, it fails saying that the password/key doesn't match the network password.
I've tried resetting the hub but no luck. Can a previous wireless network be causing a problem? Totally stumped. I;m using windows vista,
cheers
Pete
cheers
Pete
