BT Wireless offer
1 Dec 2005
Stoke on Trent
Dads thinking of getting ADSL from BT. Hes thinking of the wireless option. Is the equipment you get with it any good and will he need a pci wireless card? Im assuming yes?
afaik you get....
options 1,2,3 bt voyager 2091, wireless, usb, 1 ethernet port
option 4 with free btbroadband voice, bt voyager 2500v, wireless, usb, 4 ethernet ports, voip only compatible with btbroadband voice
the only info i can find about these routers online is on listings on very famous auction websites.... :p
i have the 2500v and it's solid as a rock except i'm not using wireless so i have no ideas about it's range. :o
not sure about the 2091 but i know my 2500v supports wpa-psk, wpa2 etc. of course you need a wireless adapter to match those same specs. :)
