Got it all working and came to get the bubbles out only to find that more appear, after about 1 minute the entire water system is white because of the amount of tiny bubbles. Im thinking its the pumps speed its a ddc ultra alphacool with 8/10mm hose, dtek fuzion and a 120.2 nexxos rad. All i have in the water is some zalman coolent and a tiny amount of uv dye.
Edit: Its like this the strange thing is im using the same res, i might try putting some sponge in as well seems to work.
http://forums.bit-tech.net/showthread.php?t=96303&highlight=sponge+water
