Bubbling/Farting From AIO Pumps
1 Mar 2014
I have this problem with both my Fury X cards and Titan Xs with AIOs.
Temps are fine and I have searched around with people mentioning that you need to shake the case a little to get the trapped air out.
In both cases the radiators are placed above the GPUs, but shaking doesn't seem to "cure" the farting.
Anyone know something else I can do ?
Try putting case on it's side and run it for a few minutes see if it moves the trapped air around.
Its one of the reasons I've moved away from such setups - for every AIO/CLC that is quiet to silent in operation I've encountered another with annoying pump noise or other coolant movement noises - sometimes solved by running for a little while with the case on its side but usually not.
