Bucled wheel, bad tyre, now snapped wheel :(
12 Apr 2007
Hey all,
Thought I had a buckled rear wheel today after I started getting a bit wobbly, flipped the bike over and thought the same.
On getting home for a better look after cleaning the wheel up a bit I notices two 'rips' in the outer layer of the tyre, one on each side, not in exactly the same place on each side but each rip is about 5 inch long and overlap 80%.
Any thoughts on why this would be? here's a pic, tyre is a rocket ron, with a good 500miles on it :oops:
I'm just checking now if the wheel is truish without a tyre on, and if so will fit a Ralph I have as a spare.
EDIT:
On further inspection there is a hairline crack in the rim, it goes all the way around, you can just about see it in the pic if you look close.
Bugger, new wheel time I guess. :cry:
I wonder if there is any way I could claim on warranty , bike is only 7 months old :cry:
Have you been riding it with a puncture? That usually causes the same sort of damage to a tyre.
I think the crack is actually just the joint. Take the tyre off and check the inside to see.
Will do, the rear tube was patched recently after an unsympathetic impact with a large stone.
The rim doesn't look bent as such.. no obvious damage or scratching.
Ill pull the tyre off clean the wheel properly and have a proper look, spinning the wheel naked on the frame.
I hope you are right! - is there often a visiblejoin seam in the rim then?
Some rims do have a little gap. My cheap single speed wheels have a gap big enough to let the light through. The rim is bent round and pinned in place. On some wheels they weld the gap, but it's not essential.
Thanks chaps, It's a bit dark to be messing now but I'll have a proper look in daylight tomorrow.
It never occurred to me it might be the rim join, guess I just assumed in this day and age rims would be solid/extruded but I guess that's for more expensive rims.
I'll know more tomorrow when I can clean things up properly and have a proper look.
Thanks
Panic over, the wheel itself is straight and the crack looks like what can only be a joint as it's dead opposite the valve hole which I guess is the strongest place for a seam.
Thanks
