Budget 21:9 Monitor
22 Feb 2010
Cleckheaton
Hi,
As title, I'm looking for a budget 21:9 monitor.
I've seen the Samsung Odyssey G55T or Dell S3422DWG so far.
The Dell looks good as it has the adjustable stand as well as USB hub which both would be nice. However these aren't killer monitor features :)
Anyone got either of these monitors and can recommend? Or any others I should look at?
The LG 38" 38GN950P-B is currently 750 quid at the OCUK shop - which is a great price (but it's not a budget monitor). There's also B-stock around 100 quid cheaper.
What are you going to use the monitor for - gaming, work or both?
That looks a great monitor.
Both gaming and work, however I’m not serious at either :)
I’ve also only got a Razer Blade with a 3080ti at the minute, so I’m worried I won’t have the power to justify the LG.
Optimum tech on you tube once did a video on budget Koorui Monitors, maybe check some of them out.
