Budget £350 or less build
22 Jun 2005
Nottinghamshire
Looking to build a home pc for just browsing, youtube etc.
My basket at Overclockers UK:
Total: £214.96
(includes shipping: £0.00)
Corsair CP-9020049-UK VS Series ATX/EPS 80 PLUS Power Supply Unit, 450 W
Asus A68HM-PLUS Motherboard (Socket FM2+, A68H, DDR3, S-ATA 600, Micro ATX, USB 3.0)
This stuff comes out at just under £300
Don't need a HDD as I have one already.
Anyone have any better ideas? I could go down the intel route, but I believe to get similar performance I would be spending a lot more?
APUs gfx performance relies upon fast RAM, there are many cheaper + faster RAM kits than that Corsair one.
I guess this would be a good choice?
Corsair Vengeance Pro 8GB (2x 4GB) 2400MHz DDR3 or
HyperX Savage 8 GB (1 x 8 GB) 2400 MHz DDR3 CL11 DIMM XMP Memory Module - Red
You wouldn't need a 450w, any good 350w would do, you won't be pushing a dedicated graphics card so you can same a few quid on that. You can also buy wifi adapters new for a tenner so you don't even need a B grade item.
I saw the difference between 350 to 450 is only a tenner so I'm not too fussed about that.
Thanks for the advice chaps!
No that's fine, your money and tenner isn't a whole lot, just was pointing out as it's an APU, it would only draw whatever the cpu is rated at, like 150w for example plus the other parts, probably wouldn't draw more than 250w.
