Budget AIRFLOW case advice.
The reset bios is only on mobo's am I right? So it would be down to which mobo and not the case?
Yes, I think you are referring to this button on the left (in this mobo):
Its for flashing the bios?
Yes that a Bios Flash Button on the Rear I/0
& yes the FARA R1 as a Reset switch on the front :)
So the Gamemax F15 Mesh arrived during the week. I have a question for the A-RGB.
Will RGB work here?
The case has a fan hub/controller with 3 pin AURA connector.
Not sure how everything will work in regards to RGB. Struggling to understand it lol. I know it means addressable that's it.
What should I be looking for in a board for this case?
@aaronjunited can I ask how do you find the case so far? I'm on the fence between 500DX and GameMax F15M. The F15M is not that popular however there are some reviews online for example by Mike's unboxing.
Anyone else who has any of these cases, can they share their experience? Mostly leaning towards GameMax F15M mostly due to how spacious it is and for supporting beefy rads like Arctic Liquid Freezer II 240/280 both front and top (280 top might be a struggle).
