take a look at the cases section before you buy a fractal
YOUR BASKET
1 x "Primo 6200i" Intel Core i5 2300 2.80GHz DDR3 Sandybridge System £379.98
1 x No Graphics Card Upgrade £0.00
1 x No Hard Drive Upgrade £0.00
1 x No Operating System £0.00
1 x System 12 Months Standard Warranty £0.00
1 x Sapphire ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card £131.99
Total : £530.57 (includes shipping : £15.50).
if you ask in the customer service section really nicely they might be able to change the case for you. the case in that build is £31.99
if you are going for a budget gaming build then i cant find anything faster than this for the money. however, its not the greatest for upgrading as it cant overclock, cant have USB3 or sata 6GB/s and cant do crossfire/SLI.
i'd wait for a couple of extra specs to come along that offer better upgradability (which will probably be sorted by getting a smaller hard drive and the i3 2100)
Thanks for the reply,
Yeah I've been flipping between a SB i5 and the 955BE for a while now, I settled on the 955 eventually as I felt an AM3 board would give better upgrade-ability, I also do a lot of multi-threaded work, which makes me want to lean towards AMD's well-known policy of MOAR COARS.
What did you mean about the case? Was that a hint that they're not so great for the money? I've always had coolermaster praetorians and I've often worried that any modern case would be a disappointment after living with brushed aluminium perfection for so long![]()
so, thats £250 worth of hard drives you've got there minimumhome server specs said:- Hard Drive: x2 2TB SATA 6GB/s (additional storage options available)
so, thats £250 worth of hard drives you've got there minimum![]()
could save yourself some pennies on the psu with this OCZ
http://www.overclockers.co.uk/showproduct.php?prodid=CA-031-OC&groupid=701&catid=123&subcat=
review here:
http://www.hardwaresecrets.com/article/OCZ-ModXStream-Pro-600-W-Power-Supply-Review/936/9
if you want to go AMD then i would spend the savings on this MSI board, it's £5 more than the gigabyte but gives you the option of SATA-6 and room for a second video card as a upgrade path in the future
http://www.overclockers.co.uk/showproduct.php?prodid=MB-134-MS&groupid=701&catid=1903&subcat=1782
its a AM3 socket but as i understand it it can support AM3+ with a BIOS update
see here:
http://emm.msi.com/display.php?List=43&N=1029
. I knew hard drive prices had rocketed but **** me (I appreciate this is nothing to do with OCUK though).i can't imagine shops are selling many at these hugely inflated prices though?
i'm using a old 80GB IDE drive in my new build until the prices come down.![]()
actually if you look at the psu in my link its 1p cheaper than the one you've linked to![]()
