Hi all,
A friend (Nokkonwud) recommended I posted here for some advice on a budget upgrade I'm planning. I already have a suitable case, monitors, peripherals etc. A 500w PSU and a GeForce FX 9600GT. I didn't really want to spend more than £300. The PC will be used for work (I'm a 3D games artist) and would need as much memory as I can afford. I was looking through the OCUK bundles and came up with this:
Then I got a little carried away:
Obviously I'd prefer to spend less but don't want parts that are going to let me down or cause a bottleneck. I'm most worried about the motherboard. Do I need to get matching chipset numbers or just socket numbers? Can I have a H61 mobo with a Z77 processor?
If you could recommend other parts that would be fantastic.
Thanks,
Matt
Thanks,
Matt
