budget build around some spare parts
1 Nov 2017
Hi,
I am looking into putting together a small computer (both in size and cost) out of some salvaged parts and some new ones. Wife won't allow big spend or a large tower sitting in the middle of the living room. I must confess I am rather rusty when it comes to parts.
The requirements for the computer are:
- reasonably small in size.
- It will probably be locked in a cabinet
- it will need to be reasonably quiet
I have an i5-4460 and a fair amount of compatible memory, mostly on 4GB sticks.
I have access to hard drives and standard ATX PSUs. If I can stretch it, I would get:
- hybrid firecuda 3.5" 1TB. Little margin here as SSDs blow the budget.
- a new PSU. As I will probably upgrade bits over time I would rather get a 500W one, I have seen some kolink ones which are not tragically expensive but would certainly take advice.
I need to source (please feel free to recommend or thrash completely):
- case. I want something small. I have seen "Silverstone - Sugo SG11B MicroATX Mini Tower Case" which is a bit dear but seems to do the trick. It's discrete and small.
- board. I am having trouble finding something here. I will probably lean towards a B85 chipset as the H81 will only take 2 sticks. Most likely I am stuck with microATX, miniITX seem a lot dearer and I will probably have more trouble running all cables. I was thinking on a "ASRock - B85M-DGS" but don't have a strong preference.
- Cooler. It has to be reasonably quiet. I was thinking "Alpenföhn - Silvretta 47.1 CFM CPU Cooler". Again, ideas?
- GPU. This may not come on day one, but the whole point of the system is to be able to occasionally play games (I'm not a gamer, I've never owned a console). So I was thinking a basic geforce 1050 (Zotac - GeForce GTX 1050 2GB Mini Video Card).
Views?
Would I need any additional fans?
I might probably add a second HDD or an optical drive, but it seems really a very distant future.
Thanks for any ideas!
R
Hello,
Have you thought about purchasing second-hand parts ? You could get a 970/980 for fairly cheap I guess, or less if it's still too expensive/you don't need that much. As for the cooler, you could find a second-hand coolermaster seidon 120m, it's quiet depending on the fan you are using on it, and does the job really great. I think new it costs around 50 euros.
I looked around for a 4 slots mini/micro-atx MB but I can't find any (at least on the websites I'm using to order my parts), but if you have already two 4gb sticks, maybe 8go will be enough for you ?
For the case, what do you think of the cooler master elite RC-342 ?
Hope it will help you sorting out your needs,
Lemon
thanks for the feedback. I know that the MB I will need to source elsewhere. H81 chipset does not have USB3 headers mid board and only 2 sticks of RAM. B85 does.
I will try to salvage a fan from somewhere and the GPU, I'll see if I can find something second hand. albeit older, it seems to be a better card than the 1050 but it's hard to get a good deal.
regarding the case, the holy inquisition would cut my thumbs with a mini tower, therein lies the problem
Thanks for the input
I think you should consider upgrading the wife instead.
In answer to your questions:
The case - providing it has enough room for a quiet CPU cooler then really just get the cheapest option you can.
Cooler - I've successfully used this one from Raijintek in a few builds and it's very quiet.
My basket at Overclockers UK:
Total: £58.08
(includes shipping: £11.10)
Motherboard - the Asus B85M-G can be had new for around £60. If you want more features go 2nd hand
Thanks for that. I had seen that case and I loved it, but thwre's some small print about the size of micro atx boards. So need to probably source the board first and measure carefully before getting the case or going miniItx which then puts up the price of the board.
