A friend of mine has asked for some advice as to a replacement PC for an ageing XP machine she has.
Other than the monitor, keyboard and mouse I don't think there is much of anything worth salvaging from the PC so I've been looking at (very) budget systems along the following lines:
- Intel Core i3-4150
- 4GB RAM
- 500GB HDD
- mATX Case
- Windows 8.1 64bit
£230 inc. delivery
or
- AMD A4-5300 APU
- 4GB DDR3 + 500GB HDD
- mATX Case
- DVD Writer
- Windows 7 Home Premium 64bit
£250 inc. delivery
My question is, are the above specs "reasonable" for a low-end user? (general internet browsing, word processing etc - no gaming) and if not, what sort of specs should I be looking at for her as a minimum?
I can't seem to see anything "low-end" on OCUK but I'd be happy to do the build for her with components within the above price brackets if possible??
Ideally Windows 7 as I find it better than Windows 8 but it's not a deal breaker!
Thanks for any help....
- 4GB RAM
- 500GB HDD
- mATX Case
- Windows 8.1 64bit
£230 inc. delivery
or
- AMD A4-5300 APU
- mATX Case
- DVD Writer
£250 inc. delivery
