Budget build help
3 Sep 2014
Hi Guys,
I need to upgrade my current PC and have a budget of around £600.
The parts I already have are:
PSU - Corsair GS700
Memory - 1 stick Corsair Vengeance Blue 8GB DDR3 1600 MHz CAS 9 (Will get some more when budget allows)
Storage - 2 x 500 GB Samsung Spinpoint F1
Case - Antec 900 mid atx
The parts I need are:
SSD - as large as possible for windows and main games
Motherboard
Gfx Card
Processor
Cheap DVD drive (black to go with case if pos)
Windows 7 / 8.1 (whichever is actually better, heard a lot of hate regarding windows 8)
I mostly play games (1080) but I also produce music using Cubase.
For this reason i was thinking of going i7 4790K for the multi threading for use with Cubase, but i'm not sure if that's stretching the budget a little too much and if I would even get the benefit over an i5 4690k.
I don't plan on overclocking and only chose the 4790k because of the difference in clock speed versus the non "k" version, and the 4690k as it only cost a little more then the non "k" version.
I am upgrading from a Q9450 and GTS450 so I should hopefully feel the difference!
Any help and advice is appreciated :)
Thank you!
Howdy
PC Pros will be along shortly, you have come to the right place.
You have ample memory, HDD and a wicked case there.
You need:
SSD
Motherboard
Gfx Card
Processor - suggest i5
DVD drive - any optical drive will do
OS I guess W8.1 is your wisest investment although I agree it looks pants
I would spend on your GFX card
The Pros are going to ask what wattage your PSU is?
Hold the phone..........................
This will be an improvement. Whilst Cubase will take advantage of the virtual cores, I'm not sure the i7 is worth the premium over the i5 for you. Everything else is fine. You're losing a small amount of performance by having only 1 stick of RAM, but it's a negligible difference really - somewhere in the order of 10%
YOUR BASKET
1 x Asus Z97-K - Devils Canyon Core i5 4690K Bundle **£14 Saving** £249.58
1 x VTX3D Radeon R9 280 3072MB GDDR5 PCI-Express Graphics Card £149.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
1 x LG GH24NSB0 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £598.13 (includes shipping : £8.00).
