Budget Build Spec me
Assuming he needs the tower + OS only
YOUR BASKET
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£14 Saving** £258.58
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £41.99
1 x BitFenix Neos ATX Tower Black/Blue £29.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £549.11 (includes shipping : £8.00).
£17.50 cashback with this mobo/CPU combo, so should bring you closer to budget
Can compromise on some stuff but this is the minimum I'd be getting
http://forums.overclockers.co.uk/showthread.php?t=18619070&highlight=gigabyte+cashback
What GPU/will you be slotting in a GPU?
YOUR BASKET
He only has a Gtx650 atm but the machine it's in is not even worthy of that low end Card. It's by far the best thing he has in his system. This Spec looks pretty nice for the money.
