Budget build
4 Jan 2009
Can you spec me a budget build for about £270.
I have OS, monitor, keyboard and mouse, speakers. i do not need a graphics card and i do not mind if it's intel or amd.
I will be adding a 4850 later on.
Mjones1.
A bit over budget, but is quite a good build.
If you could stretch another £40 or so then you could get a p43 motherboard and 4gb ram which would see you well in the long run.
I can basicly get all that off another site for about £20+ cheaper go i will maybe only buy the motherboard unless i can find another one for a decent price.
