Man of Honour
- 13 Nov 2009
- Northampton
Girlfriend wants a new system as her current laptop won't play The sims 3.
Main uses
- General Web
- Photoshop/Paintshop pro X2
- Coursework etc for sixth form.
Currently has an Advent 5421 (Intel T1500 1.86ghz 1gb ddr2)
Looking at the build below plus cheap graphics card - GTS25 or used 8800/9800
Would like to keep budget as close to above or below if possible.
I'll possibly pick up some components off MM to cut cost or get something a little quicker.
I'll probably go for a mild overclock depending what temps look like as Im not expecting great air flow in that case
Main uses
- General Web
