Budget build?
16 Feb 2011
Hi, it's upgrade time because my current pc isn't able to keep up now a days but money is tight at moment so I'm thinking I can keep the HD, Dvd, case and PSU.
So I'd be looking for a SSD, GPU, CPU and RAM. Trying to spend 400-500 that includes windows 8.
I play at the moment CSGO, dota2 and some darkfall unholy wars.
Is this possible? Thanks in advance.
It is possible and depending on how far you want to go, you should be able to get the entire lot for £500 max.
I couldn't name the brands of the parts but I can remember the PSU is 800w, the case is a full tower and is currently seating a atx board with 1 4870 and an Arctic cooler for the phenom 2 processor so space shouldn't be an issue.
All my stuffs in storage at the moment I'm away from home so couldn't tell you the exact brands/model numbers.
