- 6 Jun 2011
Hi guys,
I need to get two identical budget cases for a couple of builds that I am doing. All of the parts are sorted but the only thing that is holding me back is the case.
The budget is around £20 but I can go up to £30 if there is a real benefit. Some of you guys had suggested the Bitfenix Neos too me but I'm not sure if it is better than the alternative options? My main concern is room for cable management.
At the moment I am thinking the Zalman T1, what would you guys suggest?
Many thanks
Many thanks
the value seems to be decent, build quality not that good but dunno
