budget eyefinity - best 22" screen?
10 Dec 2004
Oxfordshire
Hi all
As I will soon have crossfire 7950s I have decided it is time for eyefinity!!
On a tight budget so just after some peoples thoughts on the best 3 cheap 22" screens I could consider to fit the bill?
Been looking at some Benq units that seems nice design around the £80 mark but its a bit of a minefield with bezel sizes etc
Ta
Ben
I know this is stating the obvious but try and go for the smallest bezel possible even if that means waiting a bit so your budget is a bit bigger as it does make a difference IMO
I had 3 22" monitors before the current setup I have now they were all different makes etc and had std bezels after a while this really started to anoy me so when I got my current monitors I shopped around and found a good price and rang OCUK and asked if they would price match as I was buying 3 and they did :)
Was looking at Asus units too, they have some nice small bezel models for sensible money
Sound advice, and good to hear from someone who has been there before.
I need to get it as right as I can first time as cant really afford other monitors if its not good :(.
Seen several people using vga screens and then making use of a converter to display port. You know if these are any good as there is a lovely Asus screen ocuk sells for a good price but think it is just VGA
Ta
Ben
