Hi all
It's been a while since I've looked at pc hardware, as I've been perfectly happy with my current setups. However, I'm debating the choice between building a pc for my gaming and media needs, or getting a console.
As such, I'd like to try and keep the prices similar, say £400 max. I already have a windows key, as well as all the required peripherals, so the budget is purely for the case and components. A silent running system would be ideal, but I obviously expect some noise in games.
Thanks!
EDIT: I also have a 120gb SSD I can reuse from my previous pc build
Thanks!
