I'm currently running a low end (compared to modern machines) Overclockers Gaming PC I bought second hand on Ebay, Quad Core i5 3540 CPU with 8GB RAM, on Windows 10 with a GTX 650 Ti. I'm using it for business plus I get a couple of hours on GTA V a the weekends. I'm getting frequent crashes even on the lowest settings and although the spec is theoretically mid-range for the GTA V requirements I suspect the GFX card may be the issue. The machine runs perfectly stable and fast for all my business software including Office 2016, Project Pro etc.
I don't want to spend a lot on a new GFX card as the whole rig only cost £300. Would a GTX760 be a worthwhile investment, and would I need a new power supply ? Or is there a cheaper alternative that will significantly improve performance ?
