Budget i5 system
19 May 2010
Trying to get as cheap as possible here, don't want to buy anything crappy though :p. Does this look ok? I have no intention to use crossfire so i'm guessing this cheap (cheapest) motherboard should do the trick? Will probably overclock at some point if not immediately, don't want to order this and find out the one £30 more is much better!
Also the Antec 300 seems a popular case, will this be ok on it's own or should i add a couple of fans to the order? I just lost £260 out of my budget to replace girlfriends netbook so no new gfx card for me, i have an old HD4870 i can use for the time being.
Out of stock though, i will keep an eye on it as i wont be ordering until Monday, if everyone on here says it's the best for the price i'll go with it.
