- 27 Mar 2014
- Newcastle Upon Tyne
Hi Guys.
I'm looking to build a system that I can fit on my TV stand in my sitting room. Trying to reduce the need for a desk/chair etc. in the house. I currently own a EXPEDIT (Or Kallax as it's now called) TV stand from Ikea. The compartment I want to fit the PC into is 320mm (W) x 320mm (H) x 380mm (D). Now the only case I can find that isn't to expensive and can fit "normal" parts into is the Cosair 250D. So I've specc'd my system around that.
Not only that I'm on a tight budget, roughly £700-£800. May be able to stretch it a little, but not sure on that at the minute. Obviously the cheaper the better, but I want to get the best bang for my buck so to speak.
I currently play games like world of warcraft, dota 2, guild wars 2 but i'm looking to try out Destiny when it's released and I also like the look of Titanfall. So having good gfx etc is essential. I also want to connect it to my Samsung 37" LED Smart TV so I can run at a decent display level with a crisp picture.
Few things I need:
* New OS as I currently run Vista
* SSD as windows is currently on my HDD
* Case must fit into the measurements listed above.
* To be as cheap, but as good as possible. Looking to order around the start of August.
Obviously if there's part that are better/cheaper please point them out. I've gone with the H100i watercooler as I know it definately fits and also the 280. Will be a slight squeeze as it's a 295mm card and I think its 300mm clearance inside the case. You guys might know better if it will fit or not, or if there's a better card.
Here's what I come up with:
YOUR BASKET
1 x Gigabyte Radeon R9 280 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card £173.99
1 x AMD A10-6800K Black Edition 4.10GHz (Socket FM2) APU Richland Quad Core Processor (AD680KWOHLBOX) £103.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
1 x Gigabyte F2A88XN-WIFI AMD A88X (Socket FM2+) DDR3 Mini ITX Motherboard £79.99
1 x SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black £77.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Corsair Obsidian Series 250D Mini ITX Compact Gaming Case - Black (CC-9011047-WW) £71.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £68.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £53.99
Total : £803.51 (includes shipping : £8.00).
Thanks guys
Few things I need:
YOUR BASKET
Thanks guys
