- 12 Feb 2009
- London
Hi guys thought I would post this up and may be some interest to others.
Basically my wife suggested she would like her own computer at home for office stuff and watching YouTube/Facebook etc. We looked around for awhile at cases that she liked but nothing really stood out. So I came up with the idea of maybe building it inside something else entirely.
A few bids later on Fleabay and we got this.
Its a normal FM/AM Bush Radio which is special edition colour supposedly in connection with something to do with the Royals.
Now for specs, everything was bought used as im trying to keep costs as low as possible. The system does not need to be super powerful and would like it to be cool and quiet as it will be sat on her desk in the sitting room so I decided on the following.
Intel Core i3 2120
Noctua NH-L9i CPU Cooler
Asus P8H61-I ITX Motherboard
4GB DDR3 (May upgrade to 8GB, will see how it gets on)
Crucial MX100 256GB SSD
Pico Style PSU that came in a old ITX case.
Windows 10 Pro
I thought it would be quite easy to fit it all in but once it arrived I realised it would be alittle tight if I wanted to keep all the original radio controls intact and visually working. The idea is to keep this looking as original as possible from the outside.
Sorry I didn't take a photo before I started hacking but this is what it was like inside.
After lots of hacking this is where its currently at
The motherboard just fits and the bracket towards the right with the reddish paper on is where the PSU board will mount. On the right hand side you can see I have drilled and filled some holes to mount 4 USB ports on the side. These are yet to be mounted yet.
Thats where im at for now until I get the CPU cooler and get it all tested.
Thanks for looking.
Intel Core i3 2120
Windows 10 Pro
Thanks for looking.
