Budget Laptop £600 max
25 May 2010
Hi, im having trouble finding a good budget laptop so figured someone on ocuk may be able to help. Looking for a good laptop for uni work and general use, must be robust as it needs to last me the minimum 3 years of uni. I'd prefer it to be faster than my current desktop if possible (Specs in sig). No real brand preference Thanks for your help in advance.
Edit : http://www.medion.com/gb/prod/MEDION+AKOYA+P6815+Laptop++(MD98294)/30015314A1 Look good?
Best loose the link Fras.
However well worth a look.
Would also suggest looking at ukhotdeals and/or Dell refurbished store UK or Asus refurbished store UK.
Regards
C.
The GT 650M will "just" outperform the HD 5770 but will be a lot more efficient.
