Afternoon gents
Having owned my SB PC for over a year now, I’ve decided to get a low end graphics card to allow me to play a few (undemanding) games and run some 3D programmes on the odd occasion (like Space Engine). I’m hoping you guys may be able to advise what would be a good budget card to allow decent play and acceptable frame rates and 3D rendering. So far the existing IGP has done me well, but I would like to investigate options for a step-up in performance. I’m not planning on playing any of the latest high end demanding games on FullHD res or anything....
My current spec is below – I’m hoping you guys would be able to suggest a few options - from the absolute budget (but better than my IGP) – to something mid-range (which I might stretch to if the price was right and it was worth it.....
). Budget = £80 – preferably £50 unless it’s really worth it.
I’d especially like something that would be compatible with my system and possibly utilise the funky “multi-graphics” capabilities of the board... (I think it has that doesn’t it...something about switching between the IGP and the graphics card....?)....
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68MA-D2H Intel Z68 (Socket 1155) DDR3 Motherboard
Coolermaster Elite 330 Case With Coolermaster eXtreme Power 500W PSU
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
HITACHI COOLSPIN HDS5C3020ALA632 2TB Internal 3.5 SATA Hard Drive -
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black)
Windows 7 including all updates and SP1
Gigabyte mobo drivers installed
VGA cable rather than HDMI (BSOD on boot when I try to run via HDMI..)
Many thanks indeed!
Many thanks indeed!
