Budget not as good as at first!
28 Jan 2011
hey guys,
my budget is quite possibly less than I thought. but due to starting my graphic design soon I need a compotent machine.
will this spec last me a fair while? :
Hanns.G HH251DPB 25" Widescreen LCD Monitor - Black £137.99
(£114.99) £275.98
(£229.98)
EVGA GeForce GTX 460 SuperClocked 768MB GDDR5 PCI-Express Graphics Card £129.98
(£108.32) £129.98
(£108.32)
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail £119.99
(£99.99) £119.99
(£99.99)
Coolermaster CM-690 II Lite Dominator Case - Black £61.26
(£51.05) £61.26
(£51.05)
Foxconn A7DA-S 3.0 AMD 790GX (Socket AM3) DDR3 Motherboard £54.98
(£45.82) £54.98
(£45.82)
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) £39.98
(£33.32) £79.96
(£66.64)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £32.99
(£27.49) £32.99
(£27.49)
Kworld Dark Pyramid D8 2.1 Speaker £24.98
(£20.82) £24.98
(£20.82)
OcUK Swift 650W Silent Power Supply £22.99
(£19.16) £22.99
(£19.16)
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) £19.39
(£16.16) £19.39
(£16.16)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.19
(£10.99) £13.19
(£10.99)
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin £5.99
(£4.99) £23.96
(£19.96)
Akasa 20/24-Pin 30cm PSU Extension Cable £4.79
(£3.99) £4.79
(£3.99)
Akasa AK-190-SM Smoke Ultra Quiet 80mm Fan - 3 pin £3.59
(£2.99) £7.18
(£5.98)
Sub Total : £726.35
ahh, great stulid. will go down that route i think.
but will that PSU be enough power yeah and also that ram is 1600, will that be compatible with the FC MB?
RTJ
RTJ
psu is plenty, and has decent number of connectors on it, ram is compatible as it is rated UPTO 1600mhz, a AMD default ram speed is 1066mhz, so will just run at that speed out of the box, until you start fiddling in the motherboards BIOS.
and please tell me why the 4 120mm and 2 80mm fans are for? the case doesnt need them, and for the price of all those fans you can get a much better case!! you dont need the extension cable either.
ahh right, I thoght for cooling, but I doubt I will be doing much OC so I really not need them? What case would you recommend?
also will the 4GB ram be sufficient as it only allows one per buyer on the offers?
RTJ
RTJ
keep that case, nothing wrong with it, just doesnt need the fans.
4GB is plenty.
what do you think,
(£114.99) £275.98
(£229.98)
(£99.99) £119.99
(£99.99)
OcUK Value GeForce GTX 465 1024MB GDDR5 PCI-Express Graphics Card with MAFIA 2 £99.98
(£83.32) £99.98
(£83.32)
(£51.05) £61.26
(£51.05)
(£45.82) £54.98
(£45.82)
BeQuiet Pure Power L7 530W Power Supply £46.99
(£39.16) £46.99
(£39.16)
(£27.49) £32.99
(£27.49)
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £31.19
(£25.99) £31.19
(£25.99)
(£20.82) £24.98
(£20.82)
(£16.16) £19.39
(£16.16)
(£10.99) £13.19
(£10.99)
Sub Total : £650.77
change the cpu to a 955be and save a £10
altering the multiplier in the bios is childs play.
the ac7 would handle the clock ok if your not overclocking, but when i changed from an ac7 to the tx3 when i had my unlocked phenom 550 i got a 7c drop in temps at load so i would go with the tx3 myself. or for about a quid more than the ac7 the hyper 212 plus is a much better cooler.
ok so hows this all in:
(£114.99) £275.98
(£229.98)
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £109.99
(£91.66) £109.99
(£91.66)
(£83.32) £99.98
(£83.32)
(£51.05) £61.26
(£51.05)
(£45.82) £54.98
(£45.82)
(£39.16) £46.99
(£39.16)
(£27.49) £32.99
(£27.49)
(£25.99) £31.19
(£25.99)
(£20.82) £24.98
(£20.82)
(£10.99) £13.19
(£10.99)
Cooler Master Hyper TX3 CPU Cooler (Socket 754/939/940/AM2/AM3/775/1155/1156) £12.49
(£10.41) £12.49
(£10.41)
Sub Total : £636.69
that would be a very nice machine :)
not sure about the length of the be quiet's cables so if your running the 8 pin up the back and through the hole at the top an extension may be required but can't see anything else.
