Morning all,
It's been a while since I last built a PC however I am putting something together which I will initially only be using in my garage with my smart bike trainer...not very taxing I know, so am trying to make it as cost effective as possible intially.
Long term I probably won't have the budget for another gaming specific setup so I will end up using this for casual gaming as well running COD maybe a bit of Fortnite etc so over the years will look to upgrade here and there when budget suits.
I've had a look at a few budget PC posts and have come up with the following:
My basket at Overclockers UK:
I already have a spare SSD so I'm not fussed about that, but I have included a RTX 2060 which I wondered if is a little overkill?
I have seen the GEFORCE GTX 1660 SUPER OC 6144MB GDDR6 PCI-EXPRESS GRAPHICS CARD being advised on many sub £800 builds so really wondered if it's worth spending the extra on a better GPU or not.
If anyone has any suggestions on the choices above I look forward to hearing them and obviously if I've selected components that are completely unsuitable (which may be the case) a point in the right direction will be appreciated.
Thanks in advance,
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £169.99
- 1 x MSI B450M Mortar MAX (Socket AM4) DDR4 mATX Motherboard= £99.95
- 1 x Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey= £59.99
- 1 x Phanteks AMP 550W 80 Plus Gold Modular Power Supply= £86.99
- 1 x CoolerMaster MasterBox Q300L Micro-ATX Case - Black Window= £44.99
- 1 x Gigabyte GeForce RTX 2060 OC Rev2 6144MB GDDR6 PCI-Express Graphics Card= £299.99
Total: £783.50 (includes shipping: £21.60)
Thanks in advance,
