I have been tasked with building a pc for my brother on a limited budget (for general use and occasional gaming), I plan to use my spare HD5770 and canabalise my old pc for its Intel q6600 and 500GB HDD. Unfortunately the motherboard, PSU and case are useless and will need to be replaced, and the 3GB of DDR2 Ram (1Gb + 2Gb 667Mhz) I have laying around probably will not cut it. Does anyone have any tips on a good motherboard, PSU and case to get? and whether or not I would get a significant performance boost by buying some new DDR3 RAM? I have around £200 to play with overall.
Thanks in advance for any advice you may have.
