- 14 Sep 2007
Hello everybody, first of all apologies as I know they're already a lot of threads about this topic because I've spent hours reading them! All that's resulted in me being more undecided than I was when I started so I thought I would specifically ask instead and hope to gain some insight from all you fine knowledgeable people.
I've been putting off upgrading my machine until Windows7 was available. I've now got a copy and figure if I'm going to reformat I should do it with some nice shiny new gear. However I'm in a dilemma over a CPU.
From reading many threads it seems like AMD Phenoms are the best budget, whereas the i5's and i7's are the best top end.
Now I'm undecided what the best upgrade route is do I -
1) Do I go with what seems like good bang-for-buck and go with the AMD 550?
2) Do I stick with some middle-ground and go with the AMD 720?
2a) Is the extra core a good substitute for the apparent drop in core clock speed from the 550?
3) Do I stretch a little bit further and go for the AMD 955 or 965?
4) If I go for 955/965 it seems a much smaller jump to go for the i5 750 instead which from reading people seem to agree is of a higher standard?
4a) It seems like either get a good deal and go for the 550 Dual Core or push the boat out and go for the i5 750?
Now here's the big question
5) I have a limited budget that *can* stretch to the i5 750 (same applies to 955/965) but at the cost of getting a sub £100 motherboard? Would this limit the gains I get from pushing to get the i5 or are the "cheap" i5 motherboards good "enough"?
5a) With the above in mind would it be better to invest the £70 saved by going with the 550 into getting a better motherboard to pair it with or investing in other areas of the machine? (or is that a better question to ask on the motherboard forums)?
I use the machine for gaming, I don't mutli-task or do video editing etc. I'm not overly concerned about benchmarking or OC'ing to the limits however I do like to OC to get a little more out of my equipment. All the processors I've OC'd have been AMD's so have a soft spot in my heart which may be influencing my decisions also!
I'm upgrading from an Athlon 64 X2 4200+ with an ATi1950 GPU so resulting upgrade should see a good improvement.
I've decided to upgrade to the ATi 5770 but probably won't X-Fire it so that's not an issue.
I have a budget of £200-£250 for Processor/Mobo which I am trying to stick to as going over that will compromise the quality of PSU & Heatsink I'll be able to get - two areas which I really would prefer not to compromise on.
Thanks in advance for reading this and also thanks for patience as I know this has been dicussed several times and I look forward to your comments!
