I wouldn't bother with phones at that price point.
It's worth paying around £100 it will be a much better experience and should last longer.
Exactly this, calls, texts, WhatsApp and Facebook that will be it.Why ops mum might only use it for calls or texts. No point getting an expensive one.
It's the black view a60, search the rainforest for it, a pretty low spec phone with 1gb ram and android 8 go.Is that £60 a month as where are you seeing an A60 for £60?
I'd look at a redmi note 7 or 8.
What are you smoking if you think £60 a month would be a budget phone. LolIs that £60 a month as where are you seeing an A60 for £60?
From my understanding is not as simple as that you can't compare it to something costing much more when you take into account Android Go.specs for the a60 look pretty poor, not sure I would want a phone with 1gb of ram even for the basic stuff your mum is doing to be honest.
especially since if she isn't tech savvy she wont bother with app management, everything will be open at once and it will grind to a halt.
Lol you really don't understand the word budget do you. Thanks anyway.Seriously save up another £40 even if it takes you a few weeks and get the redmi note 7. Your mum will be wanting something nicer.
I don't know why I bother. I'm not asking what the best £100+ phone is.
A £60 smart phone is going to be a huge step up.
Some of you are just picking numbers out of thin air for some reason. I get that you wouldn't want a £60 phone but are you really telling me the A60 won't run Facebook Lite, WhatsApp and the text and phone app.
She basically wants it to be able to use WhatsApp, currently uses her old phone as a phone and an old Amazon tablet for Facebook. She wants a cheap phone that combines the two.
Can't find it.There's a used A60 Pro (Android 9 with 3GB Ram) on the rainforest going for £63.35, it's a warehouse option so slight imperfections etc. Sorry it's not £60 or less but super close...
