Budget shuttle system power consumption woes.
Evening all,
Ive recently built a temporary budget Shuttle system whilst im saving for a new Vista / Direct X 10 machine. The specification is as follows:
Shuttle SK21G (200watt PSU as far as I know)
AMD Sempron 2800+
1Gb (2x512mb) PC3200 Geil Value RAM
Nvidia 128mb 6800 LE
160Gb Western Digital SATA Hard Disk
Pioneer DVR-111 DVD-RW Drive
Netgear Rangemax WiFi card
Everything is at stock speeds and temperatures seem to be adequate. Now my problem is with gaming, the system is only really used to play World of Warcraft and Pro Evolution Soccer 6 and very occasionally (not all the time) in a situation such as minimizing a game to look at a webpage then going back into the game, the system will crash. The screen goes blank and the monitor turns itself off and they only way to reset is to pull the power cord out of the back of the shuttle.
I think my problem lies with the system being underpowered, looking at the BIOS menu it seems my 12v rail sits between 11.6v-11.7v which I understand is too low, 5v rail is also slightly under.
So my question is, is there a graphics card that will suit my system in terms of power consumption but still be able to play the odd game?
Many thanks.
Evening all,
AMD Sempron 2800+
Many thanks.
