So I've come up with the following spec for a budget build to be used in my living room as a htpc. I had a go at spec'ing a small unit (see here), but I'm not sure that'll be powerful enough.
My only requirements is that it is good enough to play blurays smoothly, is cheap, and as quiet as possible. I've come up with the following:
I already have a hard drive and blu ray drive to use with it.
I've also priced up and AMD alternative at the same price (other components the same):
- AMD Athlon II X2 250 3.00GHz Socket AM3 2MB L2 Cache Retail
- Gigabyte GA-M68MT-S2 Geforce Socket AM3 mATX Motherboard
Will that do the job? Any improvements or suggestions?
Thanks
Thanks
