Budget works PC for basic internet work and office programs
20 Oct 2012
west sussex
Hi All,
i have been tasked to get a PC for a new worker we have.
Their job is not PC related but they will be required to use the internet and office 365 programs also word,excel etc. so we do require them to have their own station.
Nothing in terms of video/photo processing so i am guessing on board graphics will work.
However ideally 2 monitors to run off system.
Budget is approx £300-400
What i have already:
Mini tower case - maybe cannot re use depending on motherboard options?
350W PSU - Zoostorm i mean for the price is it worth trying to re use this?
2x monitors HDMI and VGA inputs on them
Keyboard + mouse
What i Need:
Main pc parts mobo,ram,cpu
PSU - depending on the above if can be re used?
Case - depending on the above if the motherboard can fit?
SSD for OS and a HDD for storage
Windows 10 licence
As i say this is budget i have thought about buying a 2nd hand on the well known bidding sites but i dont trust them in all honestly.
I think that's all the info you wonderful and helpful people need?
Thanks in advance
If it's the most simplest office use, why not just grab a Dell/HP tower from the bay? You can grab decent ones with SSDs for £100 mark, slightly better ones for £150 region.
I've bought a few in the past with no issues whatsoever. Just check the seller is reputable with positive feedback. Any issues you can return it if faulty or not as described.
Saves a lot of money :)
