Build: 2 Motherboard freak PC !
25 Feb 2016
Sup! :cool: Here I will be trying to post my build-idea I had on my mind for few months already - a 2 mobo PC. Aim is to get a PC which will be able to pull a Fallout 4 on Ultra settings as well as put text logs onto a tape memory writer (useless, is it not? :D ) - pretty much to have a compatibility right down to late 70's with both software and hardware.
It wont proceed fast, because I do it in free time and using spare money. A "thing" will be hooked together with crossover lan cable to enable exchanging data between each other.
Also I was thinking that I will make them both dependable from each other, so one could be steering another. We will see how it goes anyway :D
Things I own now:
Side 1:
Motherboard:
Good and not very expensive Asrock 970 Pro 3
CPU:
Phenom II 965 3.4 4 core
Cool stuff:
A massive Scythe Mine 2 radiator:
GFX:
Cheap Calibre Geforce GT 240 to fire everything up at the moment:
RAM:
Geil Evo Corsa 2133MHz 2x 8GB
index.php
Power supply:
Tagan 580w
HDD:
Samsung SSD 840 EVO 128GB
SIDE 2:
Motherboard:
Abit BX6
CPU:
Pentium 2 350MHz
procesador-intel-pentium-ii-350-mhz-slot-1-con-disipador-19119-MLA20165920886_092014-O.jpg
GFX:
Geforce FX5500 AGP on it's way:
RAM:
Micron 256MB 133MHz SD Ram
Power:
HP 300W PSU
HDD 1:
Quantum Fireball 3.5 Series, 4.3GB
HDD 2:
Quantum Lightning ProDrive 365MB
HDD 3:
Seagate ST225 MFM/RLL HDD
Anything else:
Qlogic QLA 1040 SCSI Controller on it's way:
:D:D:D:D:D
I wished I could witness beginning of pc master race. However my first ever cpu was q6600 which I just got 4 years ago. This staff looks so different compare to what we have today.
My first build was an AMD K62-400, hardware was indeed very much different than what we have now, was a lot less user friendly on setup.
Going to watch this build, be interesting to see how it turns out :
Ok here is the case solution I have on my mind recently.
Basically two merged Antec One cases together.
Firstly, I was thinking about employing some 19 or 21 inch server rackmount, but they are very expensive and usually too small for the job.
Here is my quick Photoshop vision, just for you to see what I imagine.
This whole thing will be lying horisontally like it is shown on white picture.
Position of them may vary a little depending on tools available atm. :)
