Build a bridge and get over it
  • Thread starter Thread starter Zip
  • Start date Start date
What are you supposed to do on levels with different elevation, such as level 10 on the new map pack?
The train just continues on in to the water..
Flubble said:
it only works once though :rolleyes:
Still stuck on what to to on level 10 new map pack.
:D:D
Only points on ground you can connect to on this level:
The mountain thing in the middle
THe corner at the right.
edit; cropped out the "level completed" bit by mistake
Was properly sketchy though :cool:
i flew past most of the levels... 7 too me a while though... im stuck on 15 now though. any hints?
edit: worked it out :D
This sint a game. Its a cleverly designed program to waste your day. Grrrr. Ever get the feeling you are learning things while doing this . . . . ?
BoomAM said:
Cool game.
But i cant get it to run in a higher res than 800x600, despite what the games menu says. :(
click "APPLY" top right
works for me at 1440x900 :D
Im stuck at Level 09.
Seems my normal bridge building techniques arnt working. :(
##EDIT##
NM, done it. :p
