- 28 Sep 2023
- Dorset, UK
Hi Overclockers!
I've never built a PC before but have been advised to go it alone rather than buy a pre built rig. Can you please check the kit list I've put together and offer advice as to whether I've got everything I need, or whether you think I should swap out certain components. Ideally I'd hope to spend £3,500 but this little lot is coming out at £4,345 so some advice on slimming it down a little without losing too much 'future proofing' would be great
For reference, I'm not looking to play games (except on rare occasions) and will mostly be using it for UE5 projects, 3D modelling (Maya / Blender), Z-Brush and Photoshop. I work in the visual effects industry, so I'm concentrating on cinematics and stills rather than gameplay.
Also, any tips on what the hell I should be doing, how to avoid cocking it up all gratefully received
Thanks so much for taking a look
Phanteks NV Series NV7 Full Tower Case
Gigabyte Z790 Aero G Motherboard
Intel i9-13900KS Processor
Corsair HX1500i Fully Modular Ultra-Low Noise ATX Digital Power Supply
Gigabyte GeForce RTX 4090 AERO OC 24G GPU
CORSAIR VENGEANCE DDR5 RAM 64GB (2x32GB) 6000MHz RAM
Samsung 990 PRO Heatsink 2TB PCIe 4.0 (up to 7,450MB/s) NVMe M.2 SSD (I'll add another one later on down the line)
CORSAIR iCUE LINK H150i RGB 360mm Liquid CPU Cooler
Phanteks D30 Fans
Corsair Premium 600W PCIe 5.0 / Gen 5 12VHPWR PSU Cable
CORSAIR CP-8920224 Premium Individually Sleeved PSU Cables
Thermal Grizzly - Kryonaut thermal paste
