Hello there!
I am planning to do my first PC build with RTX 3080 and i9-10900k. The other components I would like are 32GB RAM, 1TB SSD, 4TB hard drive.
Now... I have 2 problems, maybe 3 - first one is I don't know which of all the variants to choose. I see there are 100 different types of 3080s, 500 different types of RAMs, SSDs etc. I would like the best of the best but I am not sure which ones are they. Second problem is I don't know the rest of the components - which ones to choose. Is liquid cooling better (I think it is) but which one to choose for my build, which motherboard is the best, power supply. Do I need a sound card the best audio or that's only something in my head. What PC case to choose. I don't know nothing.
Could you suggest to me people what should I buy. A list of all the components I will need would be great great help. What instruments I need as well. Any tips for first time build etc.
Budget is around 4000 pounds
Thank you very much again and see you later!
